2022-03-30
08:04 AM
2022-09-28
02:52 PM
Oleksandra Vakariuk
After the latest update of Archicad 25 to version 5005 INT FULL. On Apple iMac 24 ”M1. the C4D add ons settings for export no longer appear.
I tried to reinstall both Archicad and add ons but the settings window for exporting to c4d no longer appears, while saving to 4D cinema from the 3D window appears.
2022-03-30 10:03 PM - edited 2022-03-30 10:07 PM
The latest Archicad build 5010 should resolve your issue. Here's the link to download it: Downloads – Graphisoft
2022-03-31 10:27 AM
We've updated, but the problem is still there. The possibility of setting the output of the 4D Export cinema add-on no longer appears.
2022-03-31 02:52 PM - edited 2022-03-31 03:02 PM
Double check the state of the Cinema4D add-on through Options > Add-On Manager. You can remove and reinstall it if there is an exclamation mark on it: Cinema 4D Exchange Add-On Downloads for Archicad 25 – Graphisoft. If no, you can report it as a bug. Here's in which state you should see the add-on:
2022-04-01 08:31 AM
The problem is solved, reinstalling new Archicad.
Thanks for your advice
2022-04-01 10:40 AM
When the iMac restarts the problem returns I have to reinstall Archicad each time to see the add-on working correctly, but when the iMac restarts the error returns.
Where can I report this bugs?
2022-04-01 10:44 AM - edited 2022-04-01 10:45 AM
@elvispettenuzzo You can report this bug to your Graphisoft local partner.
