2014-05-20 08:26 AM - last edited a month ago by Aruzhan Ilaikova
2014-05-20 07:50 PM
Jussi_ wrote:I've split your editorial post into a new thread as it has nothing to do with the Windows Vista topic.
It should be my right to open ArchiCAD file on exactly same ArchiCAD version that it was created.
2014-05-21 10:46 AM
2014-05-21 11:20 AM
Jussi_ wrote:I am not sure where they got their information from but I have heard (from Graphisoft HQ itself) that version 18 will run on the WIBU key.
By Graphisoft choice, reliable source claims that I have to switch from WibuKey to CodeMaster in order to run AC18.
2014-05-21 12:11 PM
Barry wrote:That is excellent news.
2014-05-21 05:15 PM
Jussi_ wrote:I apologize. I did misunderstand. I completely agree with you. Anyone with the suitable hardware/OS who had old versions should be able to continue to run those old versions.
I feel you misunderstood my post.
As a paying customers since AC3.3 I am aware and able to cope with new systems and changes...
I have hardware to run all ArchiCAD versions from AC4.16 onwards, if only hardware key provided me the rights to run copy-protected software.
By Graphisoft choice, reliable source claims that I have to switch from WibuKey to CodeMeter in order to run AC18. Limiting my working ArchiCAD licenses to AC10 onwards. This decision by Graphisoft is very wrong from customer stand point.
There are reason why AC7, AC9 and AC16 are meaningful versions. The next version brought changes that do not convert without tinkering. Preserving hardware and software to run old documents conversion free should be paying customers choice.
If hardware lock does not run old version - it is by Graphisoft choice. Not Microsoft or Apple choice.
2014-05-22 03:15 PM
Karl wrote:I had a similar thought: to let users that want to run older versions (I can go back to AC7 by rebooting into a OSX10.6.8 partition, which is far as I need to go, needing to access AC4.1 files, but not wishing to work in 4.1) keep their WIBU key for the older versions, and just put the newer (AC19+) on the CodeMeter key. This could entail removing some licenses from the WIBU key (say AC10-AC18) before activating the CodeMeter key so only one key would have the "current" versions. I am not in the same workflow as Jussi_, but have found bringing old versions forward in steps to work better than making 2 big leaps. I would also want to keep access to older versions.
Another possibility would be for GS to provide a special WIBU key good for AC 9 and earlier to any customer who requests it.
2014-12-12 02:45 PM
2014-12-15 05:40 AM
2014-12-15 11:22 AM
