2022-06-11 06:47 PM
Hi all:
So this probably has a very obvious answer since it doesn't look like anyone has posted about it, but how do I get Archicad to "Authorize" without a USB-A port - will a simple cable adapter (i.e. usb-c to usb-a) work? I looked in the Archicad License Manager app to see if there was a way to "convert" the CM key to a software key, but I didn't see any indication that's do-able. I'd like to keep the CM key anyway since it makes it easier to move between my iMac and the new laptop.
Thanks,
GK
Solved! Go to Solution.
2022-06-11 07:57 PM
Yes, the adapter will work. Single, or USB hub.
2022-06-11 07:57 PM
2022-06-12 12:37 AM
Thanks Ignacio!
GK
