Hi David,
It appears that there is no easy way.
I got a Dell Axim a month or so ago - same PocketPC software as the iPaq. Cool devices.
Interestingly, the first thing that I wanted to do was to use the GDL web plugin ... figured a handheld was a great way to browse through objects away from the desk. But, that won't work on 'em the way Graphisoft has it programmed at the moment.
Apple does not have a version of QuickTime posted on their site for PocketPC. I found the following web page that talks about converting a VR to a Flash animation to enable viewing on PocketPC:
http://www.cwru.edu/its/itac/nms/rd/qtvr/qtvr.html
Note that current models run PocketPC 2003 which includes the Flash player, so the Flash download mentioned in the link shouldn't be necessary.
(While I can open a QT animation on my desktop version of Windows Media Player, I can't open one on the PocketPC version.)
PocketPC's have a resolution of 240 x 320 pixels. When viewing images in the image viewer (e.g., JPG), any size image can be viewed and rotated (landscape/portrait) It is shrunk to fit the screen - but can be zoomed to any size, and then panned by just dragging the stylus around the screen. (PocketPC-based telephones have fewer pixels on the screen - not sure what their resolution is.)
For Flash/web pages/media player, some of the pixels are used by menus and other stuff, so I'm not sure what the remaining max viewable pixel area is.
HTH,
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
