You may be close to a 'user' origin and still far from the 'project' origin.
Double click the 'Set user origin' button to send it back to the project origin.
Then see how far away it is.
Or turn all layers on and zoom to extents to see if there is just maybe one element far from the project origin (check all storeys).
Also check that there is not something very high (or low) in 3D - this is basically the same problem.
I was also going to suggest checking your drivers, but if other files are OK and this file plays up on other computers, this won't be the issue.
And of course it never hurts to check that you have the latest update for your Archicad.
