2005-06-09 01:17 AM
2005-06-09 02:21 AM
i can't run my archicad on my mac power book, when it start it gives me a crash report.
I have sent the crash report to Apple and waiting for a reply, so now i can't use my archicad on my PB.
PS: it's archicad V9.
Thank you
2005-06-09 02:32 AM
2005-06-09 02:48 AM
The PB that i'm using is G4 1.67 with 1GB memory.
It has all the citeria that needs to run an archicad.
I tried to uninstall from the folder inside the archicad, and restart and install again; but nothing work.
i even tried to download the WIBU driver and install it on it.
and i tried again but nothing work.
i Update my System from the net and still nothing work.
i don't know what to do!!
2005-06-09 05:46 AM
2005-06-09 08:30 PM
ejrolon wrote:delete prefs as above is the way to go . . . also, you need to make sure that you installed archiCAD with administrator access on your PB, not just a normal user account.
1) AC should run fine in your configuration.
2) go into ~/Library/Caches and delete the folder "Graphisoft"
3) go into ~/library/Preferencs and delete any file that begins with "com.graphisoft..."
4) run Disk Utility and repair permissions on your HD
2005-06-09 11:22 PM
2005-06-12 02:21 AM
gobel wrote:Did the Graphisoft bug report start up? If it did, fill in all the details, and send it - it has the automated procedure for going ot the right place.
Guys I did all that, but still not working.
Apple they didn't reply to me until now.
kindly find attached the crash report compressed doc format, if anybody can figure out what's the problem.
By the way it works fine with my PC desktop.
Thank you for your cooperation
2005-06-12 02:27 AM
2005-06-12 11:03 AM
gobel wrote:I haven't looked too deeply into this, but my first impression is that you may have a font problem. I recollect that the installation of some old or poorly designed fonts can cause problems for some applications. I suggest stripping your fonts to a minimum and see if it makes a difference. If it does, move your fonts back in batches until the problem recurs. Hopefully you can isolate the problem font.
did anybody had the same.
2005-06-13 10:23 AM
2005-06-13 10:44 AM
2005-06-13 11:59 AM
2005-06-18 09:20 AM
2005-06-19 02:26 AM
