This is starting to get a bit technical for me.
I let my IT guys handle all the file syncing stuff.
When I work remotely, I have internet access to the server and files, just as I do in the office.
If no access, I then manually copy the file I need to work on and make sure I copy it back to the server when I can connect again.
Your NAS, I assume is syncing the files across multiple locations, similar to a cloud storage it seems to me (I might be wrong).
When ever you use any syncing system, I think it is 'user beware'.
The syncing can occur in multiple directions (machine to server, server to machine) so you would need to be sure the files are only being updated from the newest file, no matter where that file gets saved in the system.
There is also the danger of syncing files becoming corrupt if they are being worked on 'live' in Archicad.
Especially when you save multiple times quickly, while the file starts to sync.
You just need to be careful and know exactly what is happening.
I can guarantee that if you save a file in Archicad to your local hard drive, then when you open that file from the recently saved list, it will be the file that you last saved.
If you save a file to a syncing folder there could be problems as mentioned - the file is syncing while you try to save, or maybe it gets synced after you save it with another version of the file, elsewhere on the system.
Short story is, I would be very wary of syncing files.
Personally I would access directly from the office server if you can.
If you can't save yourself a local copy of the file and then save it back manually yourself.
Or at least work on a copy of the file outside of the syncing folders.
When done, copy it back to the syncing folder and let it do its thing.
I would try to avoid working on a file while it is in a syncing folder.
I may be completely wrong, as I say I let the IT guys handle all the hard stuff.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
