In your Work Environment under 'Company Standards and Schemes > Special Folders' you can set the path to your template file.
Personally I don't use that system.
I just save my template as a PLN on a server that everyone has read only access to.
As for the Work Environment itself you can export that to a common location (server) and then import it onto any machine.
It is saved as part of your operating system user profile so as far as I know it can't be shared as such from a server but can be exported and imported when ever you need to update it.
