2020-09-16 03:20 AM
2020-09-21 03:23 PM
2020-09-22 07:38 AM
2020-09-22 09:09 AM
Erwin wrote:Thanks - some great tips there! Esp. using project map rather than view map for tracing - will give it a try.
With trace and reference it always speeds things up if you trace from the Project Map rather than the View Map. Even if all the view settings are the same with your active view, I think. Certainly so if they are different.
I think SEO does benefit from raw CPU power, not sure if it is optimised for multiple cores. You can maybe see that with Task Manager in your current setup.
Sloppy SEO usage can really bring things to a crawl. Like selecting all the walls and using a roof as an operator, regardless if they walls need to be trimmed by that roof or not.
2020-09-22 06:42 PM
2020-09-22 07:29 PM
2020-09-23 12:04 AM
2020-09-24 06:31 PM
Win10 | R5 2600 | 16GB | GTX1660 |
2020-10-19 12:31 AM
2020-10-20 03:10 AM
2020-10-20 03:21 AM
