2020-04-10 11:55 PM
2020-04-11 06:59 AM
2020-04-11 08:13 AM
2020-04-11 03:06 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-04-21 04:26 AM
insideru wrote:Just get the windows 10 lol, windows 7 is pretty bagged with dualscreen stuff
We have 4 windows 10 pcs running ac23 at the office, all dual monitor. We have no problems whatsoever.
If you are running windows 7, please bear in mind that all windows versions except 10 are not officially supported. Please read the page below, detect history reviews.
System Requirements for GRAPHISOFT Products
2020-06-29 05:34 AM
2020-06-30 05:20 AM
AlexM wrote:Hi Alex,
I'm having a similar issue with one of our machines.
In this case it's AC22 - I haven't tested AC23 on it.
The file will open fine on ONE monitor. It will crash (hang on generating any 3D view) on the other.
I have swapped ports on the graphics card, swapped cables, but it's the same result each time. Interestingly, I can open it on the one screen, then move the application to the second screen and it will work fine.
Maybe try move AC to the other screen and open from there to see if it's similar to my issue!
Specs for this machine:
- AC22 (7000)
- i9700 32Gb ram
- RTX 2070
- 2 x 4K monitors
Minh Nguyen
GRAPHISOFT
2020-07-09 03:35 PM
2020-07-10 06:05 AM
Minh Nguyen
GRAPHISOFT
2020-07-10 08:16 AM
atfonit wrote:Please update your forum signature to show that you are on Windows 10 then... it still says Windows 7 on all of your posts at this moment. (The signature is a database field... when you update it, all of your posts will update.)
No I am on W10, thanks anyway
