Downloading AC24
I have tried at least 4 times to download the 2GB file, on a couple of different computers, a couple of different wifi networks, and a couple of different web browsers. It fails (at different points) each time. This is extremely disappointing. Is there any trick to this that I'm missing? Also, the support website and support contact info seem to have evaporated of GS's new website as well, which is not a good look.
Richard
AC26 (since AC6.0), Win10
12 REPLIES 12
I need to download the ArchiCAD 22 library. Where did it go?
Minh Nguyen
Lingwisyer wrote:
I only have 24 INT and 23 AUS listed on the downloads page...
Ling.
Hi Ling,
I believe the AUS version is not yet released by the local partner, therefore at the moment, you will only see INT version on our website. Even if you can download it, the licenses for Australian version are not yet updated to be used with Archicad 24, unfortunately!
Thank you for your understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Log at https://myarchicad.com/PROFILE/ and download the whole program again, then update it.
This login link takes you to a page that says its for free educational versions. However, if you log in it will take you to your personal MyArchiCAD page were you can download all of your licensed versions of the program. But even your personal MyArchiCAD page will say its for Educational Licenses - even if you have never had any. There are still problems with the new web pages.
