Installation & update
SOLVED!
Downloading older Versions of ArchiCad
I need to download ArchiCad 19 and can't find where the downloads for older versions are hidden... only updates etc.
I downloaded my original AC19 from the web onto the current machine. Now I'm switching and upgrading to a new computer and .. in transitioning to AC 21, I still need the AC19 version.
Note to self: Always get a hard copy of the program!
If someone knows the where abouts of the AC19 download... I would be soo grateful.
I will try to just copy all the program files and that may work. In any event, wondering why those older version downloads aren't available.
1 ACCEPTED SOLUTION
Solution
All recent versions and localizations of ARCHICAD are available from Graphisoft website.
AC19 version you are looking for can be downloaded here.
4 REPLIES 4
Or keep a copy of the installation file you download.
Have you tried the MyArchicad link in 'Useful Links' above?
If you have downloaded it from here before it should still be in your list to download again.
If not you may not be able to get it now as it is too old.
Otherwise contact your local distributor and they might be able to give you a link.
Solution
justdhruv
And international version?
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
Just change the 'USA' to 'INT' in the web address.
https://www.graphisoft.com/downloads/archicad/install/AC19/INT
Learn and get certified!
