2020-10-02 10:25 PM
2020-10-03 10:31 AM
Archicad 4.55 - 25 | HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Nvidia Quadro M5000 @ Windows 10 Pro x64
2020-10-03 10:11 PM
2020-10-05 05:57 AM
Miha_M wrote:Your point about being set up for future Archicad developments is a good one. I would expect to keep a new workstation for at least the 5 years I kept this one maybe more and hopefully Graphisoft will continue to development multi-threading use.
I'd suggest you take a look at previous topics, as this has been talked about before.
https://archicad-talk.graphisoft.com/viewtopic.php?f=7&t=67365
My general suggestion would be - go for a high clocked CPU with more cores, a good GPU with more CUDA or that other processing units AMD has, loads of RAM, and a fast and vast SSD. A dedicated workstation is a good choice, as it probably has error checking memory (ECC) and is expected to run very stable even under high load. A dual xeon workstation is an even better choice, as it will have double CPU core numbers. But then again, you might not need such a beast. Although Archicad does make some use of multiple CPU cores and GPU processing, it still is in an everlasting overhaul process and might take a while until it can use everything new tech has to offer. If you decide to invest into a brand new workstation model you will have one big advantage - you will be well equipped for the next few Archicad versions.
You can read more about that on Graphisoft Help Center web:https://helpcenter.graphisoft.com/knowledgebase/25850/
My workstation is way older than your computer and still does the job. It might not be as quick in some situations, but I have no problems handling larger project files.
