Setup & License forum
Dual Monitor - popup menus split between monitors
Gus
Anyone have any idea how to get the pop-up menus to pop up on one monitor or the other instead of half on one and half on the other. I understand why this happens, because windows considers the dual screens as one screen, and the menu is set to pop up in the middle of that screen. I'm just looking for a way to change this settings or something to solve this problem that probably most dual monitor users run into.
Aloha
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
1 REPLY 1
You can adjust the behavior of the monitors using the software provided with the video card.
I have mine set to 'Independent Mode' as opposed to 'Stretch Mode'. Further, all the multi-monitor controls I've seen also have a setting for the behavior of dialog boxes.
Good Luck.
