Installation & update
Dual Xeon Temp! ...is that normal?
Hi i have a Dual Xeon 2.8Ghz (No OC! ...althought is stable @ 3.21Ghz!!!) ..for rendering (Cinema 4D XL and when the cpus are in idle are about 32C ...but when rendering ...around 50+C! ....
this is the case that I have: http://www.enermax.com.tw/cs-1018new.htm
... 2x80mm front fans
... 2X80mm side fans
... 2X80mm rear fans
... 1x80mm top fan...
I bought the retail version Xeons 2.8 so I did not bother to buy new heatsinks + fans... I use the stock ones
that is all... just asking for other similar systems temps!??
thanx,
cy!
...if you want to see one of my rendering visit:
http://www.geocities.com/andronikos916
1 REPLY 1
yeah, well, i think it is normal for your system to act at this temperature while running.
i, too, have similar problem.
my system set up:
p4 3.06 ht
GA-8INXP motherboard
1gb ddram
asus 9800xt@256 ram vga.
the programmes i run are archicad 8, 8.1, art-lantis4.5, photoshop.
idle: 45-50 deg C
load: 65-70 deg C.
pretty terrible until i use water cooling from cosair hydrocool.
as for the workstation, fan cooled, normal temp like yours.
hope these will help.
Learn and get certified!
