Edit elements in Cinema 4D greyed out.
Hi
In my latest project I used to use the C4D add-on frequently. Until yesterday when editing selected elements option became unavailable. I'm not sure what is causing this problem since I didn't change anything( as far as I know).
Though, today I updated everything to be sure that is not the issue.
I'm using the latests C4D R19 and Archicad 22 with the updated add-on on iMac (both are on students licenses).
Does anybody know what can be causing this issue?
*UPDATE*
I created a simple cube in C4D and used the Send to Archicad option and check if Editing elements in Cinema 4D is available and it is. So i guess it's a matter of my original file, but i cant find the cause.
You had to start by a 3D view to have all C4D links
Then C4D will go back to Archicad by the same 3D view
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Christophe - FRANCE
Hhahah omg. That really did the trick. Thank you so much!
