Setup & License forum
Extra-large floating display AC25
FernandoMagnus
Any floating screen that has to do with locating or assigning files (save as, open) appears as very extended, occupying several times the size of the monitor, with no possibility of reducing its size.
AC25 is reinstalled. I work on MacOS Monterey.
I would appreciate help
00 Captura de pantalla 2021-11-12 a las 18.56.01.png.jpg00 Captura de pantalla 2021-11-12 a las 18.55.35.png.jpg00 Captura de pantalla 2021-11-12 a las 18.56.38.png.jpg
This is a known issue that has been discussed in several other threads.   Until Graphisoft issues another update... the workaround  is given in some of the comments (by T Simmons - a blog link, and by Eduardo Rolon - Pref Editor) on this article:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
There are other Monterey issues that you can read about in the article itself.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.7, iMac Pro
1 REPLY 1
