2008-06-05 12:16 AM
2008-06-27 06:20 PM
zucoc wrote:I've got this problem, too. I just recently had to install AC9 to open some old Plotmaker .LAY files (wish list item... allow ArchiCAD to open older file types, perhaps with a "goodie"). Anyway, I went to do the "Open with..." thing, but ArchiCAD 11 is NOT a choice. When I manually browse, and select the AC11 application, it still only opens with AC10.
right-click on a PLN file -> open with... -> select the version of archicad you want to be the default to open -> check the checkbox with always use the selected program... -> click ok
and that's it
2008-09-03 03:31 PM
2008-09-03 03:57 PM
another Moderator
2008-09-03 04:22 PM
2008-09-03 04:23 PM
2008-09-03 04:34 PM
2008-09-03 06:01 PM
jackrog1 wrote:Interesting. On the Mac, the association always defaults to the last installed version. So you would do the opposite.
Oh well. I'm probably too picky. I may even go to the extreme of uninstalling 11 getting the pln association set to 12 and then re-installing 11.
2008-09-03 08:26 PM
2008-09-04 12:53 AM
2008-09-04 01:26 AM
another Moderator
