2008-06-04 03:16 PM
2008-06-04 05:17 PM
2008-06-04 07:50 PM
2008-06-05 07:36 AM
2008-06-05 09:14 AM
2008-06-05 09:33 AM
2008-06-05 09:39 AM
zucoc wrote:Hmmm ... if you say so
right-click on a PLN file -> open with... -> select the version of archicad you want to be the default to open -> check the checkbox with always use the selected program... -> click ok
and that's it
2008-06-05 09:49 AM
zucoc wrote:That, may be the standard Windows procedure, but it doesn't work for me (note the original comment). When I try to select a different version in the 'Open With' dialog box, it still defaults to whatever version it wants. Looks like we're stuck with opening ArchiCAD and then browsing to the file, though if Graphisoft wants to fix that, I'd love to see it.
and that's it
2008-06-05 07:00 PM
BasisArchitecture wrote:You can always set up an Archicad shortcut on your desktop.zucoc wrote:That, may be the standard Windows procedure, but it doesn't work for me (note the original comment). When I try to select a different version in the 'Open With' dialog box, it still defaults to whatever version it wants. Looks like we're stuck with opening ArchiCAD and then browsing to the file, though if Graphisoft wants to fix that, I'd love to see it.
and that's it
2008-06-05 10:17 PM
Barry wrote:Thanks for such a nice tip Barry.
Then just drag and drop the file from Explorer onto the shortcut and it will open.
2008-06-27 09:20 AM
zucoc wrote:I've got this problem, too. I just recently had to install AC9 to open some old Plotmaker .LAY files (wish list item... allow ArchiCAD to open older file types, perhaps with a "goodie"). Anyway, I went to do the "Open with..." thing, but ArchiCAD 11 is NOT a choice. When I manually browse, and select the AC11 application, it still only opens with AC10.
and that's it
2008-09-03 06:31 AM
2008-09-03 06:57 AM
2008-09-03 07:22 AM
2008-09-03 07:23 AM
2008-09-03 07:34 AM
2008-09-03 09:01 AM
jackrog1 wrote:Interesting. On the Mac, the association always defaults to the last installed version. So you would do the opposite.
Oh well. I'm probably too picky. I may even go to the extreme of uninstalling 11 getting the pln association set to 12 and then re-installing 11.
2008-09-03 11:26 AM
2008-09-03 03:53 PM
2008-09-03 04:26 PM
