Setup & License forum
GPU options?
lagodue
Let's say I want to optimize my CAD GPU AND my gaming GPU in the same workstation.
If I can install 2 GPUs, how difficult is it to toggle between them?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
2 REPLIES 2
sboydturner
Graphics cards do not work that way only one of the cards and be the display card, other cards can only be used for compute if the applications you use support that (Archicad does not).
One thing you could do is to virtualise the pc into separate gaming and work PCs with different video cards setup for pass through for each virtual PC but this will require a huge amount of setup
Scott
Scott Boyd-Turner
HP ZBook Studio 15: i7-6820 ,16Gb, 1000Gb SSD, Quadro M1000, Win10 Pro
AC 23 AUS
I assume you are on Windows.
I think it is possible to specify in the display settings which GPU a specific application should use. My computer does not have an integrated GPU, only a dedicated GPU card, so I cannot show a screenshot where you can select which GPU a specific application should use, but it is possible to do.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
