Setup & License forum
Glitch or new function I dislike?
JaredBanks
Mentor
Has anyone else noticed this in v14?
When I click on the layers in the info box, the first time I look I don't see the intersection groups. The second and subsequent times I do. I'm hoping this is some weird 'convenience' that I can override. Has anyone else seen or noticed this?
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
12 REPLIES 12
JaredBanks
Mentor
And the second time I click on the same object type.
Jared Banks, AIA
David Maudlin
Jared:
I just tried this and got the same result as you, I had not noticed before, looks like a bug.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Rod Jurich
David, Jared, same here.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Must be a Mac only "feature".
No problems here on Windows.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
David Maudlin
I reported this bug to Graphisoft.
David
All,
Running AC 14 on Windows 7 on 64 bit PC & do not report the problem.
I use AC 14 on mac, and I do not have this problem
Mac OSX 10.15.7 | AC 24 INT 5000 FULL
Rod Jurich
Achille, I first thought this too.
Did you select from the INFO BOX layer box.
Because if you select a shortcut to the layer setting itself it is ok.
The bug manifests only when you select from the info box.
Rod Jurich
David Maudlin
Also when using the Layer selection pop up in a dialog box.
David
