Sorry that I missed this thread. Ed Brown of GS Tech Support gave me the solution when I recently encountered this problem. Open your nVidia settings (via display options) and turn OFF Vertical Synch. All should be fine then.
This is not a GS workaround... it is a problem (IMHO) in the default settings of the nVidia drivers. If you look at the delivered nVidia profiles for running a slew of computer games, they have this setting turned off for most (all?) of them.
Also ... check the Graphics Card database ... these things are discussed there, too.
http://archicad-talk.graphisoft.com/compatibility.php?
(The link above is at the bottom of the forum list on the main ac-talk index page.)
Hope this solves it for you - worked for me. (Thanks again, Ed.)
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
