Setup & License forum
Guideline grip takes forever to show up in AC24
BradJAllen19
I'm hoping it's not just me who has had this issue and that someone has found a fix.
When I upgraded to AC24 from AC23 I noticed that it seemed to take a really long time for the orange grip to show up when I hovered my mouse over the guideline to move it. Sometimes it won't even show up if the guideline is on top of a reference line for a wall or something. When I open an old file in AC23 I don't have this problem.
I've been working around it for a few months but it is quite annoying and I'm hoping there is just a setting in work environment or something that I need to change. I just haven't found the solution yet.
Anyone else have this issue?
Brad Allen
Designer
Ironwood Manufactured Homes Inc.
Archicad 24
Windows 10
Podolsky
Ace
No. Works instantly. I didn't notice any difference. Are you using Windows or Mac? Maybe it's a problem with graphic card? Try to update video driver to the latest and ensure, that you have the latest ArchiCAD update.
9 REPLIES 9
Podolsky
Ace
BradJAllen19
Time will tell but that seems to have worked I thought I had my drivers set to auto update but I guess not.
Thanks for the tip.
Brad Allen
Designer
Archicad 24
Windows 10
Marc H
To improve response performance, you may also disable the ‘Auto-rebuild model viewpoints continuously’ feature (in WE settings) while keeping the latent Background Updating feature active. I found this provides better responses on a large model.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC26 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Ventura OS + 2 32" Asus ProArt PAU32C (4K) Monitors
Does reducing the value of "Options>Work Environment>Input Constraints and Guide>Highlight as snap reference after x.xx sec." help?
Richard
AC25 (since AC6.0), Win10
Marc and Richard - Brad posted that updating video/graphics drivers as suggested by Podolsky resolved his issue. 🙂
One of the forum moderators   •   AC 26 USA and earlier   •   macOS 12.6.1, iMac Pro 10-Core, Radeon Pro Vega 64
Karl, thank you for pointing this out. I just posted another possibility in the event that the OP later discovered that the problem was not actually solved.
Richard
BradJAllen19
Thanks but the problem still appears to be gone.
Brad Allen
Designer
Archicad 24
Windows 10
We are having this issue. With Archicad 25, -PC-, Nvidia 3080, latest GPU driver, latest Archicad. all updated.
Thank you very much for reporting the issue!
May I ask whether the slowness appears even with a brand new file or with only some projects? We haven't received any similar cases from the first-tier support in the past, so I guess this must be a computer-specific problem.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
