Help me with Archicad 23 in windows
BRGOMEZS
I was trying to recover a file that I didn't save in Archicad 23, so I went to the Archicad>Autosave 23-1 folder. There was a file there with the name of 'database.fdb', so I copied that file and put it on the Desktop, once there, I changed the properties to .pln. My windows 11 screen started to flash white, and I can't do anything anymore, only the 'task manager' window works for me. Does anyone know any solution?
1 REPLY 1
You do not need to do this (although it should work).
Just make sure Archicad is not running (task manager) and then start a new Archicad - it should open with a restore file option.
If it it Windows OS not working, then it is probably not a problem with Archicad - you will have to trouble shoot your OS or hardware..
If it is only Archicad that is not running then try reinstalling (repairing) it.
