Setup & License forum
Hotfixes
Daniel Lindahl
Does each hotfix pick up program corrections done in previous hotfixes?
I am currently on AC17 build 3013 (Hotfix 1 installed). Haven't been using 17 for a while and just got notification of Hotfix 4. Can I skip hotfixes 2 and 3, or do they need to be installed before H4?
AC17 INT. Dell Inspiron 17R SE i7 2.4GHz, 8GB RAM, Windows 8
cheers
Daniel
Daniel Lindahl Architecture
AC20 AUS+BIMx | Dell Inspiron 17 SE IntelCore i7 64bit 3630QM 2.40GHz 8GB ram | Windows 10 Pro
Link
Hey Daniel!
Generally they are cumulative, but read this.
Link.
Daniel Lindahl
Hi Link,
Thanks for the reply.
By cumulative, I take it you have to load them all in sequence?
The link you posted in your reply didn't work. Could you please repost it, or name the topic you are pointing to.
cheers
Daniel
Link
Sorry, the hyperlink is fixed now. No generally you only need to load the last one.
Think also of when ArchiCAD checks for updates, it can only really send you to one hotfix.
Hope this helps and hope you're well.
Link.
