When you save a PLN Archicad should (if you have not changed the default settings in the Work Environment) Save the original file with a .BPN file extension - so you should have two files with the same name but different extensions.
The .PLN is what you just saved - the incorrect file.
The .BPN is the original PLN and you can open it just like any other file.
No need to rename it.
Then just save and it will become the PLN again (replacing the current PLN which will then become the BPN) or you can 'save as' and be careful about where you put it.
