Setup & License forum
I can not login
I am new user and recently took an edu license.
I have a problem, in which I don't know what to do.
I can not login either at graphisoft or at myarchicad.com
Every time I am trying to access the page, it says it can not connect "Firefox can’t establish a connection to the server at graphisoftid.graphisoft.com."
I tried Chrome, Firefox and Explorer, same result. Clear data/cache and all that and the problem persist.
I don't use any proxy server or vpn. (Windows 10)
Also Archicad 24 can not connect. I have, more or less the same message. "Can not connect to server ID, check the internet and all that"
How did i get the license? From smartphone. It appears using the smartphone, in the same network can work. I can login and do anything. But from Pc is impossible to access any of the above page.
Archicad 24 accepted the license without any problems, but it can not connect.
Any ideas?
Thank you in advance
P.s
It's possible that I posted my problem to a non relative category. Sorry for that, but I didn't know where to post it. ( I had the same issue, even before acquire a license, so it's not affected by the type of license )
P.s 2
1) https://graphisoft.com/downloads/addons/rfa
2) https://myarchicad.com/
I can view both pages, but every time I click to login, it's failing to load the webpage
Minh Nguyen
Graphisoft Moderator
Hi Harrys,
Thank you very much for your message!
I sent you the instruction on how to fix the issue. In short, there were some entries that are blocking your computer from connecting to GraphisoftID website. After removing those entries, you will be able to access without any issue!
Please let me know if it helps!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
20 REPLIES 20
It might have something to do with cross tracking in your browser.
See it this post helps ...
https://archicad-talk.graphisoft.com/viewtopic.php?f=22&t=69551&p=319886&hilit=tracking#p319812
Versions 6.5 to 25
Minh Nguyen
Hello Harry,
Thank you very much for your question and I am very sorry about the issue!
I would like to carry out a simple test: If you open this webpage: https://graphisoftid.graphisoft.com/#/login
with any browser, does it successfully load the website, or the browser reports that it cannot connect?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
No. It can not load the page. "Firefox can’t establish a connection to the server at graphisoftid.graphisoft.com."
(it's a screenshot)
https://gyazo.com/17af11282d36740851ab8c0b31ab4647
I saw the post earlier. All cookies are enabled as it described and no result.
I ll search this more, in 3 weeks because next week I have exams.
Thank you
Minh Nguyen
Hi Harrys,
Thank you for the answer. I can see where the problem is. If you are using any firewall/antivirus protection, please temporarily disable them and try to open https://graphisoftid.graphisoft.com/ again.
If the connection is still not successful, I would like to ask for the hosts file, which can be found here: C:\Windows\System32\drivers\etc\
Feel free to send me a Private Message if you decide to share the hosts file.
Thank you very much, and best of luck with your exam!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
https://gyazo.com/e74504785fb5bd0ba793b64cdd19fef6 (Nothing again)
First of all, thank you for the help.
I am not using any firewall, except the one from windows
As for the antivirus it's a free version of Antimalware Bytes. ( https://www.malwarebytes.com/ )
I've disabled it, just for the test and also the windows firewall.
As you see the result is the same. I can not see the page.
I ll send you in message the host file
Minh Nguyen
Hi Harrys,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Hi @Minh Nguyen!
Could you please send me the instructions too? I have done the instructions with deleting the #graphisoft in terminal and it still does not work. Thank you,
Grace
Dear Grace,
Thank you very much for reaching out!
If you are having the same issue described in this thread, could you please take a photo of the hosts file in your system and send it to me in a Private Message?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
mnguyen wrote:
Hi Harrys,
Best regards,
Minh
Yes it worked. I can access the page now and archicad connected.
Thank you very much
I'm having the same issue, can you please tell me the solution?
Minh Nguyen
Thank you very much for the question!
May I ask if you can sign in to GraphisoftID website using any browser in your machine?
If not, there must be something blocking the connection. But we'll get to that part later.
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
No, I can´t open the website in google chrome and safari.
Something is blocking my computer from connecting to GraphisoftID website.
Minh Nguyen
Thank you for the confirmation!
Could you send me the hosts file from the following location:
Windows: C:\Windows\System32\drivers\etc
macOS:
- Open the Terminal on macOS (Finder > Utilities > Terminal)
- Run the following command (requires admin rights and password):
sudo nano /etc/hosts
- Take a screenshot of the result
Feel free to send me a message about the result!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
I've sent you a private message, thank you
Hello!
I'm having the same problem. Can you help me, and tell me the solution?
Thank you!
Have you read this post and does it help?
https://archicad-talk.graphisoft.com/viewtopic.php?f=5&t=69843#p323297
Versions 6.5 to 25
mnguyen wrote:
macOS:
Best regards,
Minh
Hi! I followed this thread and none of the steps worked out for me, so I believe I'm also one of those cases that need to PM you with my hosts file. I'm doing so and I hope it helps!
