Installation & update
I think I broke Undo Last Node
kevin b
Just got a new job, switched from Mac to Windows, imported my old WE and my shortcuts are all screwed up because of the Command/Alt/Control differences. So I was making changes to get back to where I want things as best I can. But now I noticed that the Undo Lat Node function ie. backspace key to undo last node during a polygonal operation does not work on the imported and modified shortcuts. Still works in the default shortcuts. It does not appear to be an editable shortcut as I can't find it anywhere. So I am wondering if there is a way to fix this? Or if I am going to have to start from scratch again, using the default settings as the basis.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
1 REPLY 1
Hello kevin b,
Everyday I usualy work on macos AND windows without changing any shortcut cause I use to do it.
It takes only some minutes to be able to do naturaly the substitution between Ctrl by Cmd.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Learn and get certified!
