Installation & update
Installation error for ArchiCAD 13 on Snow Leopard
Hej,
I just downloaded the installer for ArchiCAD 13 (Mac version) from the https://myarchicad.com/ website. But when I run it nothing happens! A look in the system logs reveal the following messages:
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] [LaunchRunner Error] The main class "run" could not be found.
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] [JavaAppLauncher Error] CallStaticVoidMethod() threw an exception
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] Exception in thread "main" java.lang.NullPointerException
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] at apple.launcher.LaunchRunner.run(LaunchRunner.java:112)
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:50)
2009-11-25 20.51.40 [0x0-0x80080].ArchiCAD Installer[768] at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
2009-11-25 20.51.40 com.apple.launchd.peruser.501[167] ([0x0-0x80080].ArchiCAD Installer[768]) Exited with exit code: 1
Has anyone else experienced the same problem? Has anyone succeeded in installing ArchiCAD 13 on Snow Leopard? Does anyone know of a fix for this problem?
Would much appreciate help on this matter!
Regards,
Henrik
2 REPLIES 2
Eduardo Rolon
No
Yes , have been running it for a while.
have not seen it in the forums. You can try downloading the installer again to see is it was corrupt.
Just in case AC13 is mactel only it will not run on PPC systems.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Thanks for the reply!
I finally figured out what the problem was. I downloaded the installation dmg-file through Firefox, but for some reason the download was aborted before it finished, which of course resulted in an incomplete installation file. I tried it several times with the same result. When I attempted to download the file through Safari it worked perfectly. So now I have AC13 installed and working nicely!
Learn and get certified!
