Installation & update
Installation of new version, and in new laptop
GOBA
What should be done in order to have all the configurations as profiles I installed v24, and I didn’t have my profile. What are the steps we need to do?
And, I’ve bought a new laptop. What folders do I need to copy from the old computer to the new one? Or, is there a process to transfer all the configurations, libraries?
Thanks!
ArchiCAD user since November 2109
AC24, Windows 10
From your old machine you can export your work environment to a folder and then import this into your new installation.
Add-ons are probably best re-installed, but if you know which files they are, you can probably just copy them from the old machine to the same location on the new machine - generally in the Archicad program folder > in a folder called add-ons.
Any additional libraries that you use can be copied from the old machine to the same location on the new machine - only you know where you have saved them.
GOBA
Thanks Barry!
AC24, Windows 10
