From your old machine you can export your work environment to a folder and then import this into your new installation.
Add-ons are probably best re-installed, but if you know which files they are, you can probably just copy them from the old machine to the same location on the new machine - generally in the Archicad program folder > in a folder called add-ons.
Any additional libraries that you use can be copied from the old machine to the same location on the new machine - only you know where you have saved them.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
