Installing Goodies 25
Harriette
Hi All,
I have followed the install instructions from here: https://Graphisoft.com/downloads/goodies/ac25-uki to install the 25 goodies package (build 4013) My Archicad build is 5010 and I subsequently re-ran the update as the install instructions advised. I then closed Archicad and restarted my computer, but none of the goodies add-ons appear when I open Archicad now, even with the default workprofile. Has anyone had the same problem or can offer some tips please?
Thank you
Windows 10 Desktop, Archicad 15.5010
They get put in the normal menu structure
Check design>design extras>
Here you should see accessories, 3d studio, interior wizard.
Those are the only ones I have installed at least.
Thank you @SenecaDesignLLC
