Setup & License forum
Installing V13 - uninstall v12?
Arcadia
When installing v13 should I uninstall v12 first or can I have both versions installed on the computer in different directories with different libraries? Or should I just get rid of v12 and just update all my current files to v13? Not sure what to do as this is first time I have done an update on a version.
V12-V25, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
3 REPLIES 3
Rod Jurich
Arcadia wrote:
/.. Or should I just get rid of v12 and just update all my current files to v13?/.....
Arcadia I have versions 7 to 13 loaded and no problems.
I would keep your v12, you never know when you may need to use it specifically.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Arcadia
Thanks Rod. And I assume you have different library's for each version?
Rod Jurich
Arcadia wrote:
/...And I assume you have different library's for each version?
I have developed my own library with many parts from the 4D Library.
I have not used any ArchiCAD default library since v6.5. Instead all default libraries
are kept as masters which I borrow/copy from to my my library.
I duplicate my library and update the current default library Macro Folder with each new version.
May sound complex but no more than remembering to load migration libraries.
Library development is a constant process of improvement.
Rod Jurich
