robertf wrote:
Is it not possible to run Archicad on a tablet??
If you have it installed and it is running in demo mode then it looks like it should run.
The question is do you have your key plugged in (WIBU or Codemeter?).
If so then are the correct drivers installed.
Try installing the "License Activation" software to see if you key is being recognised.
http://www.graphisoft.com/downloads/licensing/
