2014-02-11 08:29 AM - last edited Wednesday by Aruzhan Ilaikova
2014-02-11 10:50 AM
About Java 7
ArchiCAD 17
If you installed ArchiCAD 17 with Wibu protection you might need to install Java 6 separately in order to run ArchiCAD with your key. WkConfig requires Java 6, so if it is not present on your computer use Java 6u32 installer from the above list.
ArchiCAD 16 Hotfixes
If you are installing an ArchiCAD 16 Hotfix on Windows platform, Java 6 will be required even if Java version 7 has been already installed on your computer. If Java 6 is not present on your Windows you can download and install from the links above. The two Java versions will not interfere.
Do I need older versions of Java?Just as an experiment I just removed Java 7 from my laptop and Archicad 17 still opens.
The latest available version is compatible with the older versions. However, some Java applications (or applets) can indicate that they are dependent on a particular version, and may not run if you do not have that version installed. If an application or web page you access requires an older version of Java, you should report this to the provider/developer and request that they update the application to be compatible with all Java versions.
