Installation & update
Key plug problems on OS 10.3
Ben Odonnell
Just wondering if any one has had problems with their key plug on MAC OS X.3 and ArchiCAD 8 V3. I know I know install ArchiCAD 8.1 but the Swedish version isn't done yet: If so what was the problem and was there a fix??
Cheers..
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
4 REPLIES 4
Did you reinstall the WIBU driver? ('System Components')
If you do archive and install, the WIBU driver doesn't come along.
Worked for me.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Ben Odonnell
Great Thanks for that I'll give it a try..
Ben O'Donnell
MarkG wrote:
For those on OSX, there is a new version of the WIBU key to try out - 4.0.0a available at WIBU's site. I'm using it on 10.3 client connected to a 10.2.8 server still running the 3.3.1 version of the WIBU key. All seems to be fine.
I've had no problem with 10.3 in either 8.0 or 8.1. All is fine here. By the way Mark. I love the picture. "What hump?"
Ditto no problems
