Teamwork & BIMcloud
Keyboard Shortcuts not saved
GSButler
I am using AC23 on Windows 10. I have been using my own customised keyboard shortcuts for ages which have been working just fine, but just in the last week or so I have noticed that they don't get saved when I close down a Teamwork project and start it again the next day. I have to set them all up again each day.
Has anyone else had this one?
Maitland and Butler Pty Ltd
AC18 - Windows 7 64-bit
1 REPLY 1
I've not seen or heard of that... however, you should never have to set them up again if you are using the Work Environment properly ... with a named scheme for each of the schemes, all listed in your named WE.  Nothing should change your shortcuts on its own (bug if so) - but if it happens, you just load your named shortcut scheme again.
One of the forum moderators
