Installation & update
Latest AC15 hotfix 4056 and MAC OS 10.8.3
poore
I am unable to install this hotfix on a computer running the latest MAC OS software. I get multiple errors in the log. The hotfix installed on the server and all other machines without issue. Any ideas to get around this?
7 REPLIES 7
No problems here. Can you post some info on the errors? Are any of the errors displayed visually - or does the installer just freeze, and you see the errors only in the Console app / logs?
Did you phone tech support?
One of the forum moderators
No problems for me either. On an old MacPro and the last 17" MacBook Pro.
poore
It looks like its installing and finishing. Once you hit the finish button it says that it failed. I'll copy the log here. This update is a new 27" imac.
poore
fixed
poore
Sorry- all set- uninstalled and reinstalled- everything updated properly.
Your signature says 10.7/Lion, Matthew... if you're on 10.8.3 now, you should update your sig. 😉
Good to hear - uninstall/reinstall might help someone else who runs into the same issue.
