Layout issue...
ICEdevil
i have run out of ideas...
i have a floor plan and i use layer combinations to put different information on four diffrent layouts...the first two are ok, the other two will at first display the info correctly, then they will only display the drawing's frame, without the elements inside.
i followed the same steps in creating them and any other layout that i would create from this point on would have the same problem.
i have to mention that the checkbox with "display frame only" is not checked.
so??? bug??? or am i a complete retard???
ArchiCAD 11 build 1210
ArchiCAD 12 Hotfix 3
AMD Athlon 64X2 3800+, 2 GB DDR, Nvidia geforce 6600GT, Win XP SP2
14 REPLIES 14
Rob
mate your signature shows AC11 966, it was the initial release version - get the patch and upgrade to 1200 or 1210. may be that will solve your problems straight away.
::rk
Djordje
Ace
ICEdevil wrote:
Djordje wrote:
Also, WHEN IN LAYOUT, show and unlock all layers.
but...i am using layer combinations...
wouldn't your advice be unsuitable for this?
It will not affect any model layers, just the layout layers.
Some funny things are happening there ... first, run the upgrade (1200 THEN 1210) and try. Upgrade the library, when you are there.
You know how to upgrade, don't you?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ICEdevil
everything came back to normal once the update has completed...
thanx all
Djordje
Ace
Good! Now change the signature
Djordje
HP Omen
ICEdevil
