Setup & License forum
Layout issue...
ICEdevil
i have run out of ideas...
i have a floor plan and i use layer combinations to put different information on four diffrent layouts...the first two are ok, the other two will at first display the info correctly, then they will only display the drawing's frame, without the elements inside.
i followed the same steps in creating them and any other layout that i would create from this point on would have the same problem.
i have to mention that the checkbox with "display frame only" is not checked.
so??? bug??? or am i a complete retard???
ArchiCAD 11 build 1210
ArchiCAD 12 Hotfix 3
AMD Athlon 64X2 3800+, 2 GB DDR, Nvidia geforce 6600GT, Win XP SP2
14 REPLIES 14
Rob
mate,
before we start:
1. put the AC version and platform (PC/Mac) in your signature so we can see what you're using.
2.
not sure what you mean by the info...
3. try to redefine the viewpoints again, note if you have changed the layer combo's name the viewpoint will not recognise it (known bug), so change the layer combo to whichever you need to and then re-save the viewpoint
4. refresh the drawings on layouts or eventually delete wrong drawings from layouts and place them on again
let us know how did you go...
::rk
Also if the extents or origin of the model information has changed this may have an effect on how drawings in layouts display, depending on Anchor point settings, fit frame to drawing / manually resized drawing etc. Try selecting the offending drawing on the layout, "Fit frame to drawing" in the Frame tab, then zoom extents.
Djordje
Also, WHEN IN LAYOUT, show and unlock all layers.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ICEdevil
info = drawing, plan, whatever is on the screen
i already tried redefining the viewpoints...
already refreshed them, tried the delete and re-place them method, everything is ok until i switch to plan view or close and reopen the document. then everything disappears again
today i found out that someone else at a local architecture firm has the same problem, so he uses multiple stories instead of layouts... 😕
ICEdevil
but...i am using layer combinations...
wouldn't your advice be unsuitable for this?
How? In what way? Do they not use layouts at all?
ICEdevil
i'm sorry...i'm a jackass...i meant "instead of layer combinations"
That's just as bad.
What do their sections look like?
ICEdevil
s2art wrote:
That's just as bad.
well...i don't know that... =))
but i suppose they do the section with the needed layers visible and then copy-paste it in 2D...
Rob
mate your signature shows AC11 966, it was the initial release version - get the patch and upgrade to 1200 or 1210. may be that will solve your problems straight away.
::rk
Djordje
It will not affect any model layers, just the layout layers.
Some funny things are happening there ... first, run the upgrade (1200 THEN 1210) and try. Upgrade the library, when you are there.
You know how to upgrade, don't you?
Djordje
HP Omen
ICEdevil
everything came back to normal once the update has completed...
thanx all
Djordje
Good! Now change the signature
Djordje
HP Omen
ICEdevil
