Installation & update
Library Update Trouble
When attempting to install Library Hotfix #2 I get an error message saying it cannot access one or more files in Archicad. It worked seamlessly on three other Macs in the office. Suggestions?
4 REPLIES 4
jegomez
I have the same issue. I have no Idea what to do. Any help would be appreciated.
Thanks.
ArchiCAD 15 3267 USA FULL
Windows 7 Professional - 64-bit Operating System
Intel Xeon W3550, 8gb RAM, NVIDIA Quadro 600
Some ideas:
Did you modify the LCF file?
Did you remove any folders or files from the ArchiCAD library?
Porter Fuqua
I am getting a similar error on a Windows 7 64-bit machine. The update process wouldn't initialize because there was some access error. After I uninstalled and reinstalled Archicad 14 it took the latest hotfix.
However, I just tried to install the last library update and it give the same error that I got before.
It is not my workstation but we have 5 Windows machines with nearly identical software configurations that had no problems with the update.
iMac - 2.93GHz Core i7, 4GB, OSX 10.6.7
ArchiCAD 15
Greg Kmethy
I have seen this happening when there were third-party libraries installed within the ArchiCAD Library folder. If any file or folder within the "ArchiCAD 14 Library" folder lacks "write" privileges, that could be causing this.
Gergely Kmethy
VP, Customer Success, Graphisoft
Learn and get certified!
