Installation & update
Library hotfix for ArchiCAD 12 US version
Greg Kmethy
Dear AC-Talkers
Today we have released a library update for ArchiCAD 12 US version. This Hotfix updates both the ArchiCAD 12 Library and the ArchiCAD 11 Migration Library. It is available through Help menu/Check for updates... command. The ArchiCAD automatic updater will also warn about this Hotfix. Please take a moment to read the Release Notes.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
4 REPLIES 4
Erich
I am sorry to see that the library update did not address the issue of the trim offset not only offsetting the jamb trims as expected but also the interior or exterior aprons as well. It is clear that the parameters, gs_trim_offs_in or gs_trim_offs_out, are being added/subtracted from the routine to locate the aprons but unfortunately the code is a bit too convoluted to locate this routine and fix this without a great deal of study.
Any chance of Graphisoft addressing this in the next update?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Greg Kmethy
Erich,
Thanks for the heads up, we will look into it!
Gergely Kmethy
Rakela Raul
any date for new lib hotfix ??
thank you
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Djordje
Ace
A bit offtopic: Greg, do you have any idea why did the last lib update (the current one) that I have done taken exactly three and a half hours?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Learn and get certified!
