Mac M1 Max and Archicad 25 bug in 3D
Karol Argasinski
Dear Archicad Friends,
I wanted to ask, do you have the same issue when selecting elements in 3D. Let's say I select different elements (doors, windows, etc). When I hold shift and click from one element to another, to select those which I want, in 99,99% of cases Archicad will activate the cmd+D/move function for a whole group of elements... it is, to say the least, A VERY FRUSTRATING thing. Never happened on Windows and Intel Mac.
I have to say, I am thinking about buying a second machine on Windows, after seeing the performance on M1 Max. I am not even mentioning rendering, or, the worst of them all - recalculating 2D views/sheets. It works really bad. My Fiancee's Dell laptop with intel 8th gen has better performance, in every case.
Best regards Folks,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M1 Max 10C 32GB
http://www.bimfaktoria.pl/
11 REPLIES 11
If you click on the element rather than a node you will find you can deselect ok. When you click on a node ac seems to ignore that the shift key is down
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Hi Barry,
nah it wasn't that. I had those options from the beginning. It is generaly MacOS Monterey/M1 architecture issue. I don't have it on my old Intel Macbook Pro (Macbook Pro 2014 works better than this 😄 ).
Since I need a backup machine, with a decent file/sheets loading time - do you guys recommend good ol' Thinkpad P50 i7/64GB RAM for the task?
Best
Karol
OPENBIM does works!
