2013-10-23 09:22 AM - last edited 3 weeks ago by Aruzhan Ilaikova
2013-10-28 02:45 PM
2013-10-28 05:58 PM
Ben wrote:Unfortunately, this doesn't work usefully (for me) either ... I may click the preference to go back to the Mountain Lion desktop methods...Karl wrote:
Finally found it... it is not possible to stretch apps between multiple monitors
Hi Karl
You can also do this app by app. Just right click on the running application and from 'Options' check 'Assign to all Desktops'. I guess this way you can have full screen on separate displays and still have your ArchiCAD palettes floating wherever you like. (I posted this on the original Mavericks thread)
HTH
2013-10-28 06:11 PM
Ignacio wrote:Immediately crashed on launch here, too.
Anybody succeeded opening AC10?
Process: ArchiCAD [7270] Path: /Applications/Graphisoft/*/ArchiCAD.app/Contents/MacOS/ArchiCAD Identifier: com.graphisoft.ArchiCAD Version: 10.0.0 (10.0.0) Code Type: X86 (Native) Parent Process: launchd [209] Responsible: ArchiCAD [7270] User ID: 501 Date/Time: 2013-10-28 11:10:08.296 -0600 OS Version: Mac OS X 10.9 (13A603) Report Version: 11 Anonymous UUID: CAC5DEBB-A87F-F0DB-C306-C03AFFB9F747 Sleep/Wake UUID: D58455E5-D107-4DEF-B00B-2CA8CF502A88 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
2013-10-28 06:27 PM
2013-10-28 06:44 PM
another Moderator
2013-10-28 07:18 PM
2013-10-29 12:14 AM
2013-10-29 03:25 AM
genarch wrote:Artlantis 4.1.8fc1 launches and runs fine for me, as does 5.0.2.3
Artlantis 4.1 crashes on startup under Mavericks. I understand the new Artlantis 5 does the same thing, but will start successfully if you drag and drop a file onto the app icon. That trick does not work for 4.1, unfortunately.
2013-10-29 04:49 AM
Karl wrote:Oh yeah. I don't use spaces very often....
I typically have three spaces in ML
2013-10-29 11:49 PM
Karl wrote:That's odd because Abvent says Artlantis 5.0.2.3 is incompatible.
No need for tricks. What does your crash log list as the problem on your machine?
