Installation & update
Misplacement of snap points
Did someone had to deal with misplacement of snap points of 3D object? Do you have any suggestions what could be wrong with my .pln file? I am unable to accurately manipulate with all 3D objects. This problem occured randomly. This for example is custom made truss profile I made. I am able to further edit all of my objects in 2D mode but this bugs me everytime I try to do something in 3D.
Thank you in advance
Tomas
This is what I would try.
Switch from the OpenGL engine to the Internal (Vectorial) engine in 3D to see if that makes a difference (not sure if it will).
Update your video drivers and restart your machine.
6 REPLIES 6
mikas
Or You might have your model too far from the project origin.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=68255&p=303431&hilit=origin+far#p303329
https://helpcenter.graphisoft.com/user-guide/64836/
https://asiabim.wordpress.com/2016/02/23/project-base-files-for-coordination/
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
Of course.
I always forget about that as I always model right next to the project origin.
I did change openGL to vector engine and it works! But is there any way how to....perhaps reset openGL settings? I do prefer working in opneGL over v.e.
I also tried to change position of 0,0,0 but it did not worked.
Thank you guys for your replies.
(openGL on left, vector engine on right)
Erwin Edel
You should model close to the origin, moving the origin does not solve the problem.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
As Erwin said, you will need to move the model close to the default project origin, not move the origin to the model as that is just a 'user' origin - the real project origin that everything is calculated from is still too far away.
If that doesn't work then I would say it is an OpenGL issue.
Try the driver update (and restart your machine).
