2022-06-16 08:15 PM
hi all,
I have installed and running: Archicad 25, Rhino7, Grasshopper, Archicad Grasshopper Connection BUT
I dont see that Archicad tab in Grasshopper:
Any idea what I could have missed?
Thanks!
BR, Florian
Solved! Go to Solution.
2022-06-20 03:20 PM
Thank you very much for the report!
At the moment, there are 2 different packages for the Grasshopper connection: one is for Rhino 5 & 6, the other is for Rhino 6 & 7. I'm wondering if you installed the correct addon? If not, please uninstall the old one and download the correct installer from here (the one with sub text: Supports Rhino 6 and Rhino 7)
If it doesn't work, if you open the location: C:\Program Files\Rhino 7\Plug-ins\Grasshopper, do you see the file ArchiCADConnection.gha there?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-06-16 11:30 PM
check to see that you have only one connection installed. You can't have the connection on more than one version of AC.
2022-06-16 11:52 PM
only one is installed - double checked
2022-06-20 03:20 PM
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-06-20 03:40 PM
hi,
no
thanks!
BR, Florian
2022-06-20 03:46 PM
Thanks for the info! Have you tried reinstalling using the package mentioned in the link above?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-06-22 07:14 AM
restart - reinstall solved the issue!
Thanks!
BR, Florian
2023-01-09 02:49 PM
I also don't see the Archicad tab in Grasshopper, and I got an error message when opening GH (see image attached).
I have Rhino 6, Archicad 26 4022 AUT FULL, and Grasshopper-Archicad 26 Live Connection (Rhino 6 and Rhino 7) from Oct. 28, 2022
I checked and the ArchicadConnection.gha is there in the Grasshopper folder.
Also already restarted all 3 programs and Windows, and the problem still persists.
Any help is appreciated, thank you.
