Setup & License forum
Missing photorendering palette (out of sight)
sityu
Formerly I used double monitors, now I had to change back to single.
So the photorendering palette disappeared. Probably shows somewhere out of the range of the (single) monitor.
I tried many things:
-clicking in menu, then alt, then down arrow (to get the palette repisotion);
-screen resolution change;
-the virtual desktops of w10 doesn't inculde it;
-regedit searches;
-ArchiCAD Basic.prf deletion;
-etc.
-the easiest would be getting a second monitor (but for some cases, it's hard a little);
Any suggestions?
Talmácsi, István, architect (AC user since 1997, ac4.5 - now: ac18)
5 REPLIES 5
DGSketcher
Champion
If hide and show photorendering settings in window > pallets doesn't work have you tried Options > Work Environment > Apply Profile > Standard... This will reset all your pallets so I hope you haven't done too much customising.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
Erwin Edel
It doesn't seem to be tied to anything saved in work-environment either, that would've been my suggestions.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
sityu
Tried. Didn't help.
DGSketcher
Champion
Installation reset?
http://helpcenter.graphisoft.com/troubleshooting/setup/repair-archicad/
sityu
Success!
I've tried to delete the ARCHICAD Basic.prf file in C:\Users\<UserProfile>\AppData\Roaming\Graphisoft\ARCHICAD-64 xxx.
Restarted the ArchiCAD; but no change.
It needed a complete system reboot, and it works!
