Installation & update
Morphs disappear with marquee tool
I have just recently updated my ArchiCAD 20 to the 6005 build update and I have found that when using the marquee tool to show selection in 3d, all the morphs disappear. Though I can view morph boxes or morph objects revolved, just no non-solid morph 'planes'.They are still there in 2d but are not visible in 3d.
If I view in 3d with 'show all' (same layer settings) they re-appear.
if I view in 3d with 'show all' in 3d and use the 3D cutaway tool they appear as well. (again, same layer settings)
Does anyone know what could be causing this? A bug? Some new default setting I'm not aware of?
Thanks,
Dave
Katalin Borszeki
Hi, we could not reproduce this issue on AC20 INT, nor on the AC20 USA 6005 build. Could you send us a file in a PM? best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
ksjhawk
Did anyone figure this out. I have the same issue with morph planes and lines. Using AC22 on a mac.
MacBook Pro Apple M1 Max 64GB ram
OS X 12.4
AC26 - AC6.5
