2018-07-28 09:45 PM
2018-07-29 11:59 AM
2018-08-02 06:52 AM
The system provided file browser dialog works a little different than in 10.13 worked.
We fixed this problem in ARCHICAD, it will be released in the upcoming updates (AC21 update 5, AC22 update 1).
2018-09-04 12:42 PM
archislave wrote:How do you find working with AC 22 on Mohave? Are there any problems or bugs except this one you mentioned in your post?
Does anyone know how to fix the meter wide file dialog boxes in Archicad 22 under OS X Mohave Beta? They will not compress or resize. Thanks!
2018-09-21 06:21 AM
2018-09-21 07:11 AM
rupen wrote:Done.
HI there, If you correct the spelling for the new operating system this page may be easier to find.![]()
Mojave / 10.14
2018-10-22 08:52 PM
2018-10-23 12:13 AM
fabbroni wrote:I can't say for sure but there probably won't be an update for 19.
Same problem with Archicad 19. Let's hope a fix comes soon. Obnoxious problem.
2018-10-24 04:18 AM
2018-10-24 04:57 AM
2021-11-30 08:49 PM
Exactly same issue for while. Just frustrated to get here.
2021-12-02 11:03 AM
Having the same problem in 25, running latest build
2022-01-25 12:34 AM
Same here. Found any solutions? It takes a lot of time to drag the window dialog and find the ¨open file¨ button...
2022-01-25 01:00 AM
Found an workaround as temporary solution.
https://piunikaweb.com/2021/11/29/graphisoft-aware-of-open-save-dialog-not-resizing-bug-in-Archicad-...
