2015-01-23 02:32 AM
2015-02-04 03:25 AM
2015-02-04 03:47 AM
2015-02-06 03:57 AM
2015-02-06 04:51 AM
2015-02-11 05:15 AM
2015-02-11 05:28 AM
2015-02-11 10:28 AM
2015-02-12 03:31 AM
2015-02-13 03:36 AM
Barry wrote:This doesn't happen with Codemeter (at least not since AC12 and even then I think it was fixed at some point).
I have found if a user is running Version 18, 17 and 16 at the same time it will use three separate licenses.
If a user has 3 version 18 running at the same time then it should only use one license.
But as I say I am using WIBU key - not sure if it is the same with Codemeter.
Barry wrote:The Codemeter version of this software (Codemeter Control Centre) only works for keys plugged directly into your computer. We have to go through IT to change ours the same as mach10 does.
You should be able to remotely control the licenses on the server and cancel user from any machine - although as I say I am not totally sure.
With WIBU key we have a 'Server Monitor' program - I am sure there must be something similar with Codemeter.
